Re: Opinions on some different SF \"E\" setups wanted...
[ QUOTE ]
GR said:
I'm gathering some SF "E" series parts and would like some opinions (pros/cons) on each possible combo.
1x123 body (E1e) with new KL1 or KL4
2x123 body (L4) with new KL1 or KL4
Any of the above combos with a Z57 or an McE2S (22 ohm).
Thanks
[/ QUOTE ]
Being that you asked about SF Exx series lights I will throw in my .02 in…before I bought my LionHeart lights the SF Exx lights took center stage. I still like them very much…but with the LionHearts….it's a whole different story now.
In the picture right to left is the:
E1e/KL1(Generation 3)/Z57 I really like this light…..it has a nice white beam, long run time, and a small package that always finds its way in my pocket whenever I don't want to belt carry a light and was always within arms reach while at home. The Z57 tail cap is a nice addition that replaced the stock Z52 tail cap it came with. Depending on where you buy a new E1e they now come with a Z57 if they have the new stock on hand. The beam on the KL1 Generation 3 is more of a flood when compared to the latest KL1 Generation 4 which is more of a spot with little side spill. I personally like the Gen. 3s for medium to close up work.
E2e/Z57 Good incan. light one of my first SF lights….thrown in just to show the different sizes, now used mainly as a back up in my fanny pack to the LEDs
L4/McES2 (30ohm) in a stock Z52 tail cap/E2O clip. This is the light that goes to work with me in a belt sheath used to check equipment and when taking inventory in the stock room and freezer. It has a really nice white FLOOD beam. I guess I lucked out cause on high I don't see the dreaded donut hole even on a white wall …on low the 30 ohm is a little too dim for my tastes and that nasty donut hole starts to show ….stick with the 22 ohm. The tint is really nice on the E1e and bright for a 123 body, but like I said I think I got lucky with this L4 Head. This is a nice light to EDC due to its size, which is just about my limit.
KL1/Vital Gear 3x123 This light lives in my truck's center console as an emergency light with SUPER looooonnnnnggg regulated run time and long battery storage in high heat conditions. With its wide beam is great for looking under the hood or inside glove box. The tint is a little on the blue side so it will go off the CHOP later to mod with a warmer tint.
As you can see I am more of a flood to throw person when it comes to compact lights….something to think about for your KL1 head purchase ( older or newer head ).
Disadvantages for the Exx series, these lights have none…..they do their job quite well and are high quality.
I like em….if you don't compare them to the custom lights.
