IsaacHayes
Ok, I'm about to finish my Fraen Mag mod (FT3 trilens). But after seeing the Barbolight and 20mmIMS x3, and others mod thier mag lights, I'm going to do the same. Hopefully this will give others ideas as well. Here are my plans for the best possible mod.
Here are some key points:
** I'll be using a D sized Mag because I like the way I can grip it in my hands better. I like the mag's barrel switch very much too.
** I want the HS in the head so that if you twist the head it won't destroy your luxeons as if they were mounted on a HS in the body of the mag. Hopefully I can use the HS made by b2eze for this, 1/4" thick would be best but there might not be space. <font color="navy">I know C size works, but the D head might not have enough height.</font>
** I will use emitters for best thermal path to the HS. This will allow me to also place the reflectors closer to eachother vs using Stars.
** The 20mm IMS will have the legs trimmed for the correct height. This will keep it from pressing down on the luxeon. I will glue/epoxy the reflector legs to the HS. <font color="navy">Does anyone know if you cut the first "notch" off of the reflector legs it will be the right height for emitters?</font> It might be, but not totally confirmed. So take a little at a time and test like always /ubbthreads/images/graemlins/smile.gif
** The HS will be Artic Alumina Epoxied to the ledge of the Mag head. I will sand off the anodizing of the ledge for additional thermal transfer. I will also consider drilling 3 holes and putting in screws to firmly hold the HS down in place as the AA hardens, and to provide more robustness. This step may be over kill, but if you twist the head down too much the bulb post might break the AA free if it will bottoms out. Not sure about the bulb post and how long it is. <font color="navy">You could use screws and AA grease instead if you want to have a removable assembly incase your mag head became too scuffed for your liking, while retaining great thermal transfer.</font>
** The lens will need something to hold it tight in place. I will use the stock Mag Reflector top cut in a ring to retain the original seal for this. My design does not rely on the lens pressing down on the reflectors to prevent stress to them and the luxeons, and since the HS will not move away from the Mag head ledge there may be extra space anyways. Hopefully there will be as if something hit the lens hard and it flexed, no damage would occur to the luxeons/reflectors.
And there you have it. My design hopefully with have excellent thermal transfer, and durability. I like soldered connections, but hopefully the bulb post method will not have much losses, allowing you to swap bodies or heads and not worrying about twisting anything.
Alternatvively, you could not use the bulb post, but solder wires to the luxeons, and out the back of the HS epoxy the wires solid so they can't yank on the luxeon leads. Then run the wires very long and coil them up into the body of the Mag after you solder them directly to the cut down switch. This would be a permanent mod that still allowed for some turning of the head incase it got in hands of other people who didn't know better.
This all depends (for the D size mag anyways) if there is enough room in the head for all of these things. Hopefully there is and some space between the lens and reflectors. If not then maybe a 1/8" thick HS would have to do. /ubbthreads/images/graemlins/frown.gif
Anyone who could let me know if the room is there please post! If not anyone who can provide measurements of these items please do as well! Thanks!!
** Mag C Head- Space from ledge to top: 27.4mm
** Mag D Head- Space from ledge to top: 19.4mm
** Mag Reflector Lip Space: 1.3mm
** IMS 20mm- Height: 18.4mm
** 1/4" HS height: 6.5mm
Lots of text, but hopefully very educational /ubbthreads/images/graemlins/smile.gif
