KevinL
This one has got me /ubbthreads/images/graemlins/Christo_pull_hair.gif
Normally the recommended configuration for direct drive is a K-bin Vf Luxeon 3, 3C NiMH or 3C alkaline. I have that.
Problem is I'm getting only 400mA through the Luxeon with freshly charged cells hot off my Maha C777 or fresh alkies from the pack. It's a star, so I confirmed bin on the back, and I've even managed to take a Vf measurement by powering everything up, and touching my DMM to the positive and negative leads of the emitter itself (the emitter sitting on the star MCPCB that is).
I completely don't get it at all. I've tried isolating every possible point of failure to the extent of soldering the star directly to the battery pack with the only break in the connection for my DMM. I've even tried changing chemistry to lithium ion (3.7V nominal) only to get the same result. What's going on?
The only possible fix to the problem is to switch to 4C NiMH, which yields a working current of 700-800mA, which is exactly what I want. However, my housing can only accomodate 3C cells.
The stars themselves have had around 5-6 power-on hours in order to try and break them in, too.
Any /ubbthreads/images/graemlins/help.gif welcome...
