[ QUOTE ]
Aux said:
Is it the heat buildup? What makes the L2 designed to run on the lower setting primarily?
[/ QUOTE ]
This is all my opinion, but:
1. Yeah, I worry about the heat - but then again SF knows what they are doing, and I worry about a lot of silly things for no good reason. I don't doubt it's in spec. However, given the same two semiconductor devices, if one of them is obviously running cooler, well, I feel better about that. I don't worry about this excessively on the L2 - I practically never run the high beam for more than 2-3 minutes at a time anyway, so this really isn't an issue.
2. The L2's regulated runtime on high is sort short to my way of thinking - 40-50 minutes. The runtime on low is several hours. The output on low is useful in most situations where you're in the dark - it's plenty of light to light up a room or walk around. So I've found 90% of the time I'm using mine on the low setting, and only using high when I really need to light stuff up.
If you mainly need it on high, it seems like you'd use an L4, which is smaller. (Or in my case, the L6, which has a superior runtime, and lots more throw.)
