[ QUOTE ]
CromagNet said:
Hi there Caspertoo. Welcome to CPF. Hope you stay a while /ubbthreads/images/graemlins/smile.gif I have 3 Tigerlights for hobby collecting. I posted a lot of pics in the review section. Just look for Tiger11 Vs. Stock TigerLight thread. You will see how to hook up the battery.
I don't think it's as easy as changing M*g batteries, but it isn't too bad. Just unscrew the bezel. Carefully unplug the potted bulb/reflector, and slide out the battery pack. Then unplug the battery pack like you would a 9V battery and plug in your reserve. Then carefully plug in the potted reflector/bulb and screw on the bezel with lense. Viola. Pro'ly 30-seconds with practice.
WAIT a minute... brb... forget that last paragraph. Just unscrew it at the Gold ring area. That way to dont have to mess with the lamp assembly. The battery pack just slides right out. Then you unplug the pack and plug in the fresh pack with the 9V battery style connection. VERY easy and fast. Still under 30-seconds but less steps and less chance to drop or damage bulb and reflector. /ubbthreads/images/graemlins/grin.gif
Sounds like a good idea to have a spare battery but charging it takes a loooong time. about 10-hours.
[/ QUOTE ]
Tony,
LOL! Neat idea, but it would be very hard to unscrew the whole head (at the gold ring) with your hands. In fact, my guess is that it would be impossible. It is NOT meant to ever be unscrewed and was installed with locktite or similar at the factory. You CAN take it off with some serious force (flashlightlens.com did this and posted it as "My 10.75" TigerLight" or something like that) but it will never be the same again and would require machining and sealing at the threads to be reassembled and secure and rain proof.
Just don't try it.
Changing the battery in the field is a nightmare, and was simply not meant to be done. It's not that it can't be done; it's just that it's darned inconvenient and if done in haste could result in damage to the lamp leads, as these tend to get caught on the rubber shock isolation gasket. My suggestion would be to carry TWO complete TigerLights in your car or maybe one in the car one on the belt, or something like that. An extra battery is $50+. An extra TigerLight (without the charging system) isn't too much more. $90 or so, IIRC.
