I have noticed on my mini mag some times if I bump the head while on or some thing like that it will flicker or the red light will come on. It is almost like it is loosing ground. I think the one little ground tab is geting pushed away which is losing ground.. Has any one ever put a spacer under the spring to add more tension? Is there any way to permanetly ground it and the just use a tail switch? Or any other ideas welcome..
later snapper
later snapper
