Hi all. Due to increasing interest in my TSP tri lens->reflector project, I thought I'd write a review. I received my three 20mm CadResearch/IMS reflectors from PhotonFanatic today. They were well packed and arrived in about three days, thanks PhotonFanatic!
It was easy enough installing them, and they do indeed fit perfectly. For each reflector, I cut off 2 of the 3 feet and cut just a bit (perhaps .7mm) off of the third one. They sit nicely on the emitters, and the third foot keeps them level. I used hot glue to attach the legs to the board, it seems to work fine. I took the spring off, it is easily pulled off of the center bolt.
Upon screwing the bezel back on I was pleased to see that it screwed onto the body of the light completely, with no gap. I like this. The lens is a tiny bit loose... It could easily be fixed with some tape or something. It's not a big concern to me at the moment.
Enough babble, here are the beamshots:
It's pretty similar, isn't it? The hotspot with the IMS is a little hotter, but there is still PLENTY of sidespill. I love the beam pattern, it's much cleaner than that of the tri-lens. Three IMS reflectors produce a decently tight hotspot with a large, even triangle terminating in a circle.
Here they are...
Overall, I'm satisfied. It looks almost the same as the tri lens but with very clean sidespill. I'm waiting for it to get dark outside at which point I may add more beamshots and thoughts.
-Crow
Here they are...
-Crow
