daBear
I have a total of 21mm from the top of the heat sink to the bottom of the lens holder on a D Cell Mag head I am attempting to mod. I want to use SO20AX reflectors which if un modified take up 18.415mm and the lens itself is 2mm leaving less that 1mm to play with.
Question is: If using a LuxIII Star does it raise the reflector or will the legs of the reflector fit into the groves on the star and fit flat down on the heat sink I am using? (b2eze supplied the HS) Also if an emitter is used rather than a star will that save any room or will it just slip under the legs of the SO20AX?
Thanks,
daBear (novice moder, but having a good time)
Thanks,
