InitialImage
- Joined
- Nov 30, 2003
- Messages
- 41
I need some help with a light I plan on making. I'm about to get back into canoeing again and I'm designing a custom bow light for use during night paddling. I will be modifying a mag head or machining a custom head that will house four luxIII leds. I plan to run one continuous from a 6 volt power supply. The other three I plan to run from a six volt power supply that will be switched on only when more light is needed. I need to be able to use either 4D cell alkalines or 4 Dcell rechargeables.
Here are my questions:
What circuit should I use to power a luxIII from 6 volts?
Do I run the other three direct drive or should I use some sort of circuit for them also? If so what do you suggest?
Depending on suggestions you have, what type of runtime can I expect from each setup?
Thanks for your help and expertise.
