My Fry's electronics used to until I cleaned them out of these resistors. /ubbthreads/images/graemlins/grin.gif
Good luck on that project.
When you get the star, mark it's (-) "leg" with a black marker before pulling it from the star.
There are some threads with instructions for pulling emitters from stars safely.
Clip the leads back a little after pulling the emitter to protect them.
I use a sharp pair of scissor blades to clean off the crud from under a pulled emitter.
I put my resistor on the negative ground wire in, just in case it shorts. = Nothing bad happens.
Just keep the wire from resistor to led insulated all the way there as you would with the positive lead wire.
