skillet
Question about \"current\" (I) events.....
Still a little confused about something...... If I have a device, say a 1.5vdc motor that draws .5 mA while operating. If I hook this motor to a AA battery and it runs 45 minutes it should run much longer on D size (able to supply the same current for a longer time) so if I put this same motor on a 1.5VDC lead acid battery, I could just go on vacation and leave it.... So.... to my point....
Are LED's not the same way as long as the supplied voltage is within tolerance? I am a little confused still... I know that more Amphours usually means longer run times if the device has a constant current usage for operation.. So what is the difference, if any, with LED technology.
Thanks
skillet
Thanks
skillet
