Bill,
LEDs work as current-driven devices, and the voltage-current curve is VERY steep. Along the lines of 0.1V per 100ma in-spec. Also, as they heat up, their resistance drops so unless there is a current regulator circuit, you could go into thermal runaway and fry the Lux.
Incans work more as voltage-driven devices. You supply the right voltage and the current that flows through the bulb is the result of that voltage.
Yes you can overdrive leds, but not to the same degree as incans. Also as mentioned above, there is a rapid drop-off in rate of return past the spec current. With spec current of 700 ma, you can usually drive a LuxIII orV to 1000ma or maybe 1300ma with good heatsinking. Past that and you're just heating up the led with no real gain in lumens. Remember that that is still 15% to 85% overdrive!!!!
All that said, 9V supplied to a Lux will be almost instant death, except for maybe a W-bin-Vf LuxV at the high end of the Vf scale.
