QIII mod (with pics and beamshots)
absoLite
This is my first mod, see what I did to my Nuwai Quantum QIII:
- inserted a O-ring to make it stand on it's tail for candle mode
- removed the clip
- put a 10 Ohm resistor in the tailcap to make it two-stage (desired brightness is selected by turning the tailcap)
- replaced the stock SX1K with a TWOJ
- flattened the bezel to make it shorter and better suited for EDC
and now the pics:
These are the parts, SX1K unsoldered:
Solder the TWOJ in place:
A look into the 2-stage tailcap
Bezel view
Side view
Beamshot in low mode (QIII was 1m from wall)
Beamshot in high mode (QIII was 1m from wall)
Former_Mag_User
Wow, great mod! Sign me up as well /ubbthreads/images/graemlins/wink.gif
How did you flatten the bezel?
absoLite
Former Mag User,
I sanded the bezel with a grinding wheel, then
used several types of sandpaper for the finish.
CroMAGnet
Los Gatos, CA
Nice job for a first mod. Can you explain the twist dual stage resistor part in detail for us cromags to try on our own? /ubbthreads/images/graemlins/smile.gif
absoLite
CromagNet,
here it goes:
I opened the tailcap, then unscrewed the plastic ring which holds the switch spring with a needle nose pliers.
Removed the spring from that plastic ring, cut that part of the spring that makes contact with the switch.
Inserted a 10 Ohm resistor, soldered it to the spring, the other side goes to the switch contact.
Then I added a spring wire that shortcuts the resistor when the tailcap is fully screwed in for full brightness.
And for low mode the tailcap has to be unscrewed about 1/4 turn. /ubbthreads/images/graemlins/smile.gif
