KevinL
The Mag3X lineage continues..... /ubbthreads/images/graemlins/grin.gif
modamag was kind enough to relieve me of my money.... *cough* err, I mean *cough* provide me with a Mag1D that I couldn't resist /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/twakfl.gif it is a pewter 2D that has been cutdown and re-threaded (and re-threaded much better than the original threads which were off by a little) so as to accomodate only one D cell.
Together with an Elektrolumens 3toD adapter, I put 3 Sanyo 2100mAH cells into the light for 3.6V. 3.6V and K-bin Luxeons means more Mag3X!
This time I requested a custom flat disk sink with no PR base, did the chopping of the Mag switch core as portrayed in the OA4D Cookbook, and soldered the 24AWG lines directly to the switch core for the LEAST possible resistance in the path. Current freaks tend to do that /ubbthreads/images/graemlins/grin.gif (hey, at least I didn't use "J" Vf bins! /ubbthreads/images/graemlins/evilgrin07.gif)
A couple of drops of cyanoacrylate served as thread lockers to bind the head to the body so that some hapless user doesn't tear it loose by accident, however as a safeguard against some he-man using brute force on it, the lines have been left long to provide strain relief. None of the Mag3X are focusable anyway. m
Thus, the Mag3X-1D is born. Shorter, smaller, and lighter. However, given the limitations of D-cell heads, I could not get SO20XAs to fit. Actually, you can get them to fit, but the outer O-ring does not seal tightly, compromising water resistance of the light, so I went with SO17XAs for this particular mod. It's still bright and beautiful, but it doesn't reach out and ping something like the 20mm reflectors do. On the other hand, you get a SUPERB flood close up and much better performance (IMHO) than optics.
Additionally, it weighs less. 500 grams (1.1lbs) vs 750 grams (1.65lbs) when fully loaded with NiMH cells. I like to travel light, too /ubbthreads/images/graemlins/grin.gif
So in a nutshell: 3 x Lux3 just like its precursor, 3 x SO17XA, 3 x AA NiMH.
Since this thread is worthless without pics, let me post a few. More to follow later.
Still looks like an ordinary Mag, but shorter:
Mmmm...pretty colors!
That's the first indication of when you know it's not your normal Mag:
