Sorry clyons -
My bad.
WA/CA stands for Welch Allyn / Carley. the two most popular bulb companies that we buy from. WA has a 100.00 minimum order and Carley has a $50.00 minimum order requirement, so most people either join in a GB (group buy), or Light-edge.com is now starting to stock the most common superbulbs.
Let's start simple...The
M@g 2C/2D
The simplest mod is for the 2C/2D using a KPR112 (from Radio Shack) and 3 litho 123 batts. For a more reliable bulb, you can use a 5-cell krypton
M@glite bulb (found at Meijers or some Hardware stores).
All that you need is
a bit of plastic plumbing pipe (long enough and big enough I.D. to insert the 123 batts into)
duct tape (to wrap around the pipe until it fits in the
M@g body)
Some folks have used the foam heater hose to house the batts, but I haven't found it to be all that sturdy.
Reassemble your light and you're good to go.
Then using the same 3 - 123 batts, you can power the Carley 1057, Carley 1499, Carley 928, etc. These will have varying runtimes but we'll save that for another time.
Tip of the day. If you take the Scotch Magic tape (green package)or the Satin tape (purple package) and afix it to the lens, it will get rid of those ugly rings and artifacts and make the beam look surefire-like.
If you do a search 'KPR112' you should find quite a bit on info.
Give this a try and let us know what you think!
greg
