Britt,
Yeah. I thought of that as I was driving home today. I know one thing for sure:
1. Hot air can be "drier"--i.e. have a lower relative humidity--but still have a greater absolute moisture content, than cooler air.
2. When surrounded by an impermiable barrier, this moisture will be forced out of the air if it cools past the point where the RH gets to 100 percent.
3. On the other hand, cooler air that is warmed up, gets "drier".
So, if you are CERTAIN that the air in your drying cupboard has no more absolute moisture than the air in the rest of your house, then it is fine to close up the light while it is hot. But if there is a source of moisture near the hot area (such as a water heater, maybe ? --honestly not sure--not trying to be snide) then the RH of the air could be low, but the absolute moisture content could be greater.
There are a lot of considerations and variables to get straight, and it's more or less impossible to say in general, but still, my point is just that if you leave the head/bezel open to the room air, any room air that gets in will actually warm up and have as low or lower an RH as the hot air inside. So it can't hurt, and if the hot air has a significantly greater absolute mositure content in it, then it could help.
I think that that's correct. But I don't know for sure. Whatever has worked for you in the past is probably the best thing to continue to do, and JorgeM can pick the method he thinks best. My way has worked for me so far, but that hardly means its the only way.
