jchock
OK,
I'm just posting this because I've been a lurker for a couple years, and only recently a poster. I was reading a bit about the easily moddable Q3 and thought I'd try it out. Most of the easy mods consisted of changing the lens to a UCL and changing to an IMS reflector for more throw. Nobody seemed to quantify this (or I simply missed the threads). Curiosity went beyond my ability to just hope someone did... I went to eBay and bought an elcheapo CHICOM Lux Meter. I got this after I made the first mods, so there's no starting reading, so ASSUMING its roughly equivalent to the one that FlashlightReviews has, that means that a completely unmodded Q3 has about 600 lux at the center of the beam at 1m. That's the theoretical start.
I got two Q3s. I also got two IMS 20mm reflectors and two 22.6mm UCLs from Flashlight Lens. I dropped these into the Q3s first thing (easy). I also made the switch sit deeper with a #21 o-ring from Home depot (doesn't affect output so it will not be mentioned here in).
I then modded the circuit with an output cap and diode. I was unimpressed initially because, my naked eye can't tell the difference. I then went on to change only one of these (one had an SYOL the other had an SYOJ Lux III, I changed the SYOJ). The first thing I changed was the sense resistor. It had an R020 resistor, I put a .033 and .047 ohm resistor in parallel. Then I got a TV1J from the SandwichShoppe (TWOJs are on order from other threads), I replaced the SYOJ star with the TV1J.
This is when the lux meter arrived in the mail.
So, lux readings at the center of the beam are as follows for the following changes:
unmodded Q3 (FlashlightReviews): <font color="blue">600</font>lux/1m
ETA:unmodded Q3, SYOJ (HaveBlue later in thread): <font color="blue">680</font>lux/1m
ETA: Q3, factory circuit, with SYOL, IMS, 22.6mm UCL, R020 factory sense: <font color="blue">750</font>lux/1m
ETA: Q3, factory circuit, with SYOL, IMS, 22.6mm UCL, R020 in parallel with .033ohm: <font color="blue">800</font>lux/1m
Output diode/caps, SYOL, IMS, 22.6mmUCL, R020 factory sense resistor: <font color="blue">880</font>lux/1m on fresh battery, about <font color="blue">700</font> on a used one.
Output diode/caps, SYOL, IMS, 22.6mmUCL, R020 in parallel with a .033ohm resistor: <font color="blue">1050</font>lux/1m on a fresh battery.
Output diode/caps, TV1J, IMS, 22.6mmUCL, R020 in parallel with a .033 and .047ohm resistor: <font color="blue">1300</font>lux/1m on a fresh battery.
ETA: Output diode/caps, TWOJ, IMS, 22.6mmUCL, R020 in parallel with a .033 and .047ohm resistor: <font color="blue">1300-1350</font>lux/1m on a fresh battery.
ETA: NexGen 2x.12ohm board, TWOJ, IMS, 22.6mmUCL: <font color="blue">about 1700</font>lux/1m on a fresh battery.
ETA: With the Zetex ZHSC310 based Q3:
factory (Z310 circuit), SX1K Lux3, factory reflector/lens: <font color="blue">370-400</font> lux/1m
Z310 Q3, removed capacitors, TV1J Lux3, factory reflector/lens, factory R020 sense resistor: <font color="blue">430</font> lux/1m
Z310 Q3, removed capacitors, TV1J Lux3, factory reflector/lens, sense resistor R020 with .033ohm in parallel: <font color="blue">530</font> lux/1m
Z310 Q3, removed capacitors, TV1J Lux3, IMS reflector, 22.6mm UCL, sense resistor R020 with .033ohm in parallel: <font color="blue">900</font> lux/1m
The TW0J/NexGen moddedTV1J modded one is the one I carry around right now as EDC (its my first EDC, I usually made due with my ASP navigator and a SF in my bag). The TV1J one will not run on some batteries that the SYOL one will. Those batteries are mostly run down, they work in my SF KL3 body, but they _BLINK_ in the modded Q3 with TV1J. They will run in the SYOL one.
Also, this thing produces a lot of heat. Not BBQ-your-hand-heat, but the unmodded Q3 never really got warm for me. The TV1J one I've only ever felt like running upto 25 min, so I have no true runtime data on it. I know that the original Q3 ran for quite a while before I changed it. Changing from the original circuit to the output caps/diode did change the heat output of the light. Changing the sense resistor merely increased the heat. I do not have an unmodded Q3 to try changing the sense resistor only. Someone else can try that an post some measured results.
With the "blinking" of the TV1J (it blinked when it was only a SYOJ with modded sense resistor), I don't think I can play with using this to run down the batteries I pull from my SF Z3/P91 HOLA light.
I just wish I could find a (cheap) drop in momentary on switch now...
