deezdrama05
Hello all Ive been a lurcker here for some time but now I must speak. Any advice help will be appreciated. I got my first greenie about 2 weeks ago (leadlight 105 from vital spirit) I took her apart and found the pot hole was already in the plastic and the brass ring was already marked, I realigned it to confirm it was(it was) and cranked up the pot wich made it 3x brighter and thats all Ive done to modify it. My led meter reads 33mw using the 2.8 for my value. It is very bright at night but does and will not burn or melt any type of black plastic- Ive tried everything at point blank range for 45-60 sec. This tells me it has to be under 30mw. I really want my laser to be close to 45-50mw so I can smoke plastic objects and have a very nice beam. What should I do? sell it and try my luck with another leadlight? What kind of additional results can I get from a resistor mod? I tried shorting the pot for a quick second but noticed no difference in beam brightness. Ive also seen gas trapped diodes on ebay what benifits would one of these have? Any suggestions on if I should further try to increase my output or should I just shell out cash for gauranteed 40-50mw laser?
