I have a DPSS-5 from Z-bolt that is the same as a BTG-2 pointer. The two wires go to a photo detector. The green infa-red filter is at a angle and reflects a portion of the beam up to the PD. This does not stop you from increasing the drive current to the diode, but may stabalize output swings some. I pot modded the one I have also. When I got it it was only doing like 3mw. After increasing the current it went to 15-21mw depending one ambient temperature. Mine was a module(just the thing inside a pointer) so I mounted thru the middle of a pentium 1 heatsink. I ran it 1 hour or more at a time and it did not get warm. It lasted about 10 hours. I think the MCA crystal roasted because I took the Z-bolt diode and driver off, and tried a hotter diode and only got a funny shaped beam(green) of 1/10 mw.
