My first lathe-done light mod project--how\'d I do?
Now that the Atlas is 99% back together I figured I'd try a light. Worked out pretty well. It started with one of several old 5C Kel-Lites I got a while ago. This one had some serious corrosion problems towards the tail:
...so it went into the parts bucket. Until its time of rebirth was at hand. Chucked it in the lathe (a little iffy, since my through-hole can't take the light's body) and parted off the rear 2/3s. Then I faced and chamfered the surface. After that, I tried my first-ever interal threading (no practice or anything--it's not too hard) with a bad boring bar that came with the machine. The result:
So we ended up with a nice, compact 2C Kel-Lite. This one's sort of a parts-bin special, so it's a little beat all-around. The head and bezel I used were a weirdly discolored and mismatched set (for those who know the breed, it's not a stainless bezel from a BTL) I found. Probably originally black, but now two shades of graphite/gunmetal:
Right now it's running 2xC with an X102 bulb, but I'll do the PVC+3x123 trick with a 6-cell xenon or 5-cell krypton. Should be pretty bright for the size. I think Juancho has a stock 2C he did that to. Compared to what it looked like before and a vintage SF 6P:
Size-wise it's a few inches shorter than a 2C Mag--only 6.5" overall. Bulb, reflector, and switch royally blow compared to a Mag, but it is 30 years old after all.
All-in-all I'm happy with the way the project turned out. My machining actually is better than the original. They were done quite poorly on manual machines--no two lights have the same fit. I'd appreciate any opinions or critiques you guys have. Now we just need a name. The Keli? Special-K? Bobbit-Lite? /ubbthreads/images/graemlins/smile.gif
