[ QUOTE ]
Sproles said:
So, when looking at some of the newer lights that have either Xenon or Luxeon (Pentagonlights and Streamlight) are their advantages to one over the other?
[/ QUOTE ]
Which is better, LEDs or Xenon? The answer is: it depends.
The big advantages of LEDs are:
- runtime
- regulation
- resistance to breakage
LEDs tend to run longer than incands. Most incand. lights aren't regulated, which means they dim continuously as you use them. The other issue with incand. lights, especially lithium cell powered lights, is that when they finally stop producing lights, it happens in a real hurry. (It's really disconcerting to be hiking and have this happen to your incand. light.) Regulated LEDs, on the other hand, produce constant light for a longer period of time, typically, and when they drop out of regulation, they tend to produce a fair amount of light for quite some time.
Xenon's tend to throw better than LEDs, especially in fog and smoke, and then tend to be more visible under bright ambient light, for example, looking in the shadows of a typical urban alleyway. (There are some regulated incandescent lights, by the way, but they aren't common.)
I use my lights mainly when I hike at night. The runtime and resilience to damage are enormous benefits for me in LED lights. I tend to use my lights continuously for one to three hours at a stretch. If my light fails, depending on where I am, I may be in real trouble. (In fact I carry a couple of lights if I'm out.)
On the other hand, a police officer in an urban setting might well decide that the lights I really like (my favorite's are a Surefire L6 and L2), really don't work well in his environment. In that setting, an incandescent with rechargeable batteries is likely to be a lot more useful.
So what do you want to do with the light mostly?What's more important to you, lighting up an area, or illuminating something as far away as possible? (Both are valid choices!) Will you use the light intermittantly or continuously for long periods? Will you use it nightly, or just on occasion?
There is no single answer as to which is better - it depends on what you are doing.
