I have modified a 4D Mag with an O-sink,2.2 ohm resistor and a TV1L emitter.
1. Do I need to fasten the resistor to something inside the light?
I used a 2.2 ohm, 5w metal film resistor. It is the square white type. I wrapped the connections and then the entire thing in silicone tape. I'm not worried about it shorting out but could the soldered connections loosen from being jostled about? If it should be fastened, how do you do this and where? FWIW the light is pulling 840 mA on 4 new Duracell batteries.
2. Can I use 2 2 watt resistors in parallel?
The electronics store near me doesn't have too many of the low ohm 5 watt resistors and I didn't see any 3 watt. They have a pretty good selection of 2 watt round ones. Can I solder 2 of these in parallel to get over the 3 watts minimum recommended for this setup? I'm pretty sure I'd just use double the wanted resistance to get the value I want but am I correct in assuming this would handle 4 watts?
3. Does Arctic Alumina ( not the epoxy ) hold the O-sink in place once it sets?
When I take the head off this light the O-sink rises up about 2mm. It looks like the reflector is the only thing holding it down. Should I put the AA (non E)on the O-sink and then MacGyver something to hold it in place until it sets?
4. What resistor value should be used in a 3D to allow using NiMH or alkaline batteries with either a TW0K or TV1L?
I think I read that NiMH need a little more resistance. I have on hand .9, 1.0 and 1.2 ohm resistors.
