KevinL
Letting go a PEWTER cut-down Mag3X light. This light shares the same front-end as the original Mag3X, including T-bin Luxeon 3s, SO20XA reflectors and Ultra Clear (UCL) glass lens.
The difference is in the color and the fact that the light is much shorter than the original Mag3X due to the use of lithium ion cells - it's set up to be driven on either a Pila 168A or 18650 unprotected lithium ion. Cells are not included. End users are responsible for provisioning their own cells and chargers. Pila 168As and chargers can be obtained from http://www.jsburlys.com . I'm including a basic sleeve made out of rolled paper. You can 'roll your own' if you choose to use Pila 168S (thinner) cells and I'm sure you can come up with a nicer sleeve than I can anyway.. /ubbthreads/images/graemlins/smile.gif
The body is a pewter 2C that was cut down to fit a 18650 and machine work was facilitated by modamag - those of you who own lights from him will know how clean and precise the cutdown job is.
Due to the fact that this Mag3X-18650 retains the modular PR-base plug that the original did, you can actually unscrew the entire head assembly, and screw it onto a 3C-cell Mag body (alkaline and NiMH compatible) to get more runtime. I could swap bodies between the two lights shown above and run on NiMH or lithium ion.
Asking $120 shipped anywhere in the world. Post here to claim the light and send cash PP to kevin [at] htgk.org . If you need to use CC Paypal, send me a PM. Normal PP fees apply. Thanks!
Price adjusted. $80 if you just want the light engine alone.
