Re: How would you mod a Mag 3C?
I just finished a Mag 3D direct drive mod. TVIL Lux III, heatsink from Yaesumofo, AA thermal epoxy to stick the LED to the sink, a little wire, solder, and read the mod walk throughs in the Cookbook, Light Refineries, & anything else you can find. Really, quite easy, once you know how. I took the blue switch module out of the assembly to solder the wires. It slides right back in after the soldering. That works better for me than soldering down a hole. Have a short,smaller,good quality soldering iron, the leads on the LEDs are TINY /ubbthreads/images/graemlins/Christo_pull_hair.gif If you do your own, it will be rewarding. I think I may try another one day. /ubbthreads/images/graemlins/smile.gif
