I just recently finished modding this headlamp. I recently traded for a bunch of 26,000 mcd LEDs and figured they would be perfect for this headlamp I picked up at a closeout at Target. It was a halloween headlamp I paid $2.00 plus tax for that is essentially identical to rayovacs headlamp costing about $6. I had to sand off the white pumpkins.
I used the booster circuit I got from a cell phone gadget I have used in a 2AA disney kids light. I got it to put out about 240ma off freshly charged nimh cells with an input of about 600 ma. I currently have used heavy duty batteries in it from construction/testing that are down to 100ma input to the boost circuit and it is still bright enough to read a book by. Here are the pictures I was able to get that were not too blurry.
Here is the circuit and coil I wrapped. I used predrilled board and use bell wire (solid ~16-18gauge) I stripped insulation off to wire the LEDs to running the wires inbetween the LEDs and connecting them with jumpers.
I used a scroll saw and a dremel to cut out the cross pattern on the reflector to help capture some of the sidespill. I also used the dremel to remove the plastic light bulb bridge inside the light. I soldered wires directly to the metal plates connected to the battery holder.
finished light
The 26kmcd LEDs don't make a beautiful pattern but it is still rather bright and very useful and appears to be a good battery drainer. On the bench the light was putting out useful light down to 45ma input, approx 15ma to the 12 LEDs combined.
Total cost of the mod:
booster circuit $1.09
Host headlamp $2.17
12 LEDs $5.60
ferrite core $0.60
Total $9.46
I hope to be able to get more of these cheap booster circuits for my other 2 headlamp hosts, at $2 each I bought 3 of them. I hope to also try using 2 or 3 of these circuits in a 2D/2C cell light with 24 or more LEDs.
finished light
Host headlamp $2.17
12 LEDs $5.60
ferrite core $0.60
Total $9.46
