I am in dental school right now and have been seeing ads for new LED curing lights for use with tooth-colored composite resins. The one I saw looked about the size of a sonicare toothbrush and was advertised as having a six minute runtime between charging. They were charging $600 for it.
The polymerization reaction in composite materials is initiated at a peak of 470 nm. The curing light I have now uses a projector type bulb that is filtered to provide the right wavelength, hence the blue light you see the dentist put in your mouth.
Have any of you seen these (LED type) or know enough about to describe their internals to me. I have to think that with the collective knowledge of this forum I could find out how to build my own killer curing light for <$600. But I may be completely wrong.
My main questions are what type of LED they use, how they would get the right wavelength, and what type of battery source do you think they use. My curing light is quite bright and I imagine the LED type should be similar. It is not so bright however to make me think that a six minute runtime is all one could get from a power source.
Any ideas would be appreciated. I don't know much more than the basics so any knowledge you have would be enlightening.
