voodoogreg
HDS Basic 60. My thought\'s after 3 1/2 weeks
I got my basic 60 roughly 3-4 weeks ago. after a few days I then had to leave for GB and Europe to do a 2 1/2 week tour. That was a perfect way to field test the light in my working environment.
Before i left i had used the light a good bit, being a "basic" it was easy to learn the UI, four levels with five way's of accessing them.
I am most impressed with this light. it has become
my main light for most thing's, esp in situation's were a light is called on for mutiple tasks, (bright, long throw, to medium level, good for navigating stair's to stage's and
double checking stage equipment, very dim for reading or checking your watch or cell/PDA in a hotel or bus without waking other tired grumpy band mates.
the quality is the best i have ever had in a light. finish is top notch, the LED and reflector is centered perfectly,
the thread's are clean running, and the switch is easy to activate with a short throw and great tactile feel.
you get the feeling that everything on it was designed for a purpose, from the wire battery holder, to easy replacement of the len's, a body shape/waist cut that invite's all the popular grip's for operation, weather it's cigar, palm/thumb style, or index finger on button/w thumb/middle/ring finger's supporting body, and perfect knurling that is agressive enough to keep the light totally
secure while operating, yet not so sharp that it would saw up cloth's or holster's. I use the clip end with a small split ring for lanyard use.
The light produced is pure white, and has a great beam, with lot's of throw, good spill and very smooth looking. in fact till i tried it against known light's i wasn't sure it was as bright as i expected, but indeed it is. It's just so smooth and pleasing beam wise you miss how bright it is it at first. I was able to light up a back wall in a 9K-12K
seat theater i played in, don't know how far away the wall was in ft but it wasn't close!
It truly exceeded my expectation's, and i intend to get an ultimate 60 soon.
any minus's? I would prefer the primary brightness to be
higher, closer to say a LS arc, but that is something that I can do with the ultimate, and it really is personal preference nothing to do with the light.
This light is real winner, and I think it was executed so well, and perform's so good it will be pretty timeless.
Great job Henry! VDG
