The light dimension is 14.33mm x 74.93mm or 0.564" x 2.950". The finish is good and thread runs smoothly. The switch is spring loaded uses twist on action. There's an o-ring at the end, should make it waterproof.
I managed to remove the circuit assembly without any damage without removing the bezel. The bezel seems to be press fitted like Inovas. I will try belyo's ice poppin method soon.
The circuit is very simple. 1 diode, 1 capacitor, 1 transistor, 1 inductor with two seperate windings. Current consumption of this light is 190mA @ 1.3volts, which translates to long runtime. I have not measure the LED current yet, will do it soon. Not exceeding bright. The output ranks a bit below a stock Arc-AAA. However it is still brighter than the early version of CMG Infinity. It wouldn't be hard to swap the LED to a 26KCd. I will post a picture of the circuit assembly next.
The $4 rate is ebay bid .I can get more of these but they are $5.6 a pop at 10 units. I am really tied up with my job at the moment so it's hard for me to organize a groupbuy. I will try to contact the ebay person to see if he's willing to ship to other countries. So it looks like ordering from the website is a good way. I am not working for them, I got the link from google.
-vince.
