NikolaTesla
I dropped my Mag 85 with the light on. Well that bulb only lasted for another hour. Kinda figured that. Then I put a new bulb in it. I had only used it for a few minutes at a time and it seemed ok. I used the first bulb for 30 minutes no problem- head got warm , no problem . Unit has UCL glass lens and FiveMega reflector and battery holder. I was using the light for about 10 minutes. It had been inside house, not cold- no condinsation. Well it started to fog up inside. Every thing was real clean (I thought) them POP! like the bulb exploded. Glass turned white and broke into a lot of small pieces (not lens but bulb). Anybody seen this before? did I do something wrong? The battery was not freshly charged either. This time I cleanded up light and relamped it. I also heated it up real good with hair dryer to drive out any moisure as my Orings are siliconed real well and it wount leak. Comments?
NikolaTesla /ubbthreads/images/graemlins/ooo.gif
An Arc lamp is the Spark that takes away the Dark--
http://f2.pg.photos.yahoo.com/ph/tomw9sx/slideshow?&.dir=/c6ab&.src=ph
