There is an interesting post in the battery / electronics secton on the effect of Vf over time. IIRC, if you run a Lux III at nominally 800 - 900ma, well heat sinked, for 24 hours, the Vf will drop down essentially one level, so your L will become approx a K bin. - please check the original post for the details.
I perceive this as some kind of anneal process going on in the LED.
This will allow your light to work potentially at the desired current without the resistor, although, certainly, a resistor is better. I had some custom 2 ohm, 1206 size, power resistors made for my own use because I wanted to run resistored lights from 2x123, which is similar to your application. If you have more space, there are plenty of larger power resistors out there at low cost. You will need at leat 2 watts rating.
