wquiles
I noticed that my KL4 always get pretty hot when it runs, but that my L6 does not even come close to in terms of heat. Both are supposed to have a 5 watt LED (right? /ubbthreads/images/graemlins/confused.gif ) so I decided to measure how much current its going on each one with different battery combinations.
First I tried the KL4 head on a 1xcell Vital Gear with a 4.2V rechargable cell. I measured 1400-1500mA on the KL4.
I then re-ran the KL4 test but on a 2xcell Vital Gear with two primary 123 cells (two different brands), and I got about 900-950mA. The KL4 gets very warm, but not nearly as bad.
Then tested the L6, and I only get about 650mA (either with 3 brand new SF 123 cells, or with two fully charged Pila 150s batteries). This would at least explain why the L6 barely gets warm.
Why if the L6 so much lower? Shouldn't the L6 be able to dissipate much more heat on the larger head and body combo? Am I missing something here? Is it simply that the KL6 was setup more conservatively by SF? Or is this due to the Luxeon lottery and perhaps my KL4 having a better binned LED than on the KL6?
The other thing, why would the KL4 head draw more on a single 4.2v cell? I can only imagine that the circuit on the KL4 head is terribly ineficcient when trying to work from the single 4.2V cell than working at the "normal" 6V. Any other reason for this? Even if I assume that the "normal" current for the KL4 is about 900-950mA, why is this so much higher than the KL6?
Finally, being that I would like to drive the KL6 much harder given the excellent heat-sinking on the head/body, what options do I have to make this "better"? /ubbthreads/images/graemlins/naughty.gif
Will
Will
