this_is_nascar
With the recent craze of R123 cells, I thought it be nice if someone were to make a simple 123-tube for the Lionhearts. Although I doubt that will happen anytime soon, if at all, I decided to investigate what it would take to power my LH with an R123 cell. Since the off-the-charger voltage of the 150a and R123 is pretty much the same, I'm figuring the only thing you loss if powered by an R123 is runtime. Not bad for someone who has a bunch of R123's and only one or two 150a's.
That being said, I've discovered that the battery spacer that comes with DSpeck's UBH is a compatable size to allow an R123 or standard 123 cell to work in the 150a LH tube. Ideally, it could be a few more MM longer and slightly rounder to elliminate some rattle, but bottom line it does work and works quite nicely.
I have not performed any runtime test at all. I'm not sure that I'll do so, but I'm tickled to know my LH now has another power source. This is great for me traveling, since I can now take my tiny Nano charger and a couple R123's and be covered.
For those of you how have purchased the complete UBH Kit or spacers package, give it a try. Use the smallest spacer that came with the package. I believe its original intent was to allow the useage of an Arc LS bezel on the UBH.
