Let's see if I can get this in before the thread gets locked. . .
Candlepower is intensity, but lumens is total output. You can have a high-intensity (high candlepower) light with a tight spot that only puts out a few lumens. Or you can have a flood light with a low-intensity beam that puts out a lot of lumens.
The technical answer is this:
The candela (cd) is the SI (metric) unit for luminous intensity. The lumen (lm) is the SI unit for luminous flux. One lumen is the flux through one steridian (solid angle measure) at 1 cd intensity.
Scott
