[ QUOTE ]
GarageBoy said:
I was referring to that insanely bright light on the right. (then read your other thread that you said the camera made it appear brighter than it was)
[/ QUOTE ]
OK, perhaps a bit of explanation is needed.
I do NOT use a fixed exposure (ie: aperture, shutter speed, ISO sensitivity) for all my beams shots - since those would range from the very unbright "dim" eternaLight on dimmest 5% setting (on 1 LED) to things like 3watt Luxeon (clone) and Xenon lights - a huge range.
I do side-by-side comparison beamshots and use the camera's metering system to get the "best" representation of the differences - hence the "optimized" exposure and one at -2 stops Underexposed to emphasize the differences and color.
So the beamshots are not absolutes and one canNOT compare one photo with another -
since these beamshots are the lights in the actual photo compared relative to each other only.
(even two separate shots that contain one light exactly the same are NOT comparable)
Perhaps little more explanation to clarify things is in order.
Lets take this very exaggerated example:
(1) comparison beamshot of ArcAAA vs eternalight on dimmest 5% white setting (on 1 LED).
(2) comparison of 1watt Luxeon vs ArcAAA.
Beamshot (1) would show the ArcAAA as "insanely" bright compared to the eternalight on dimmest 5% setting.
Beamshot (2) would show the ArcAAA as "pitiful", and in comparison the Luxeon would be "insanely" bright
- because this beamshot is strictly a comparison of the the Luxeon vs. ArcAAA -
and one cannot compare one photo to another -
since beamshot (1) would have a very bright ArcAAA, but in beamshot (2) the exact same ArcAAA would or should be "pitiful"......
With the latest configuration (as shown above) there are still some "tricks" I have to figure out - because I am trying to include the entire beam/sidespill - sometimes it leaves the central area unlit - which seems to fool not only the focussing system but the exposure system as well.
My previous comparison beamshots used only a single standard letter sized paper so there was considerable overlap of the beam side-spill - and those shots tended to compare the central hotspots -
this was fine for my earlier lights like the single 5mm LED class - the ArcAAA, Ultra-G, Dorcy 1AAA etc - where the most useful areas of light was in the hotspot.
However with brighter LEDs like the Luxeon, I needed to take the sidespill since those areas are a lot more useful/used, hence the change in setup.
