Re: Series or parallel for multiple LED\'s?
Oh I'm so confuuuuuused... /ubbthreads/images/graemlins/Christo_pull_hair.gif
I don't have all the design details worked out, but I envision the mod as this:
Three 100 ma MJLED's poking up through the top surface of a cylinder made of exotic wood (somwhere around 2 1/2" diameter and 4" high). It's to be more of a a pretty mod as opposed to the butt ugly other one I'm making which is for pure functionality. Should wind up looking like a three wick candle made of wood and LED's. I'm using the MJ's in the hope that their side emitter-like properties will give off a more candle-like effect, and they're bright.
The reasons for the 3 to D holder is that it will nicely allow for the form factor I want while being able to at least pump 4.5V from a small area, and I'm desperately looking for a home for my one EL/Waion 3 to D that I have left. If 6V using a 4 to D holder really would be a much better thing for this mod, then I'll get one.
Back to the subject, and thanks for dealing with the newbie questions... just want to make sure I get this straight.
So say I've got my 4.5V. If the LED's are in series, and they each have a Vf of (average) 3.3V @ 100 ma, it'll require 9.9V to drive them but only 100 ma of current? This would require a boost circuit I imagine?
Conversely, in parallel it would take only 3.3V but 300 ma to light 'em up? This would need a step down circuit?
Oh, and also... with a little practice I can do small soldering within reason, but I've never done SMD. Checking out the Fatman, it not only looks like it would work nicely, but it also doesn't appear to use a length of wire for a sense resistor. That works, but I'd like the neatness of a little resistor on the board instead. I have to find out about how to set the current on it. It's also a neat, little circular thing which also fits the form factor.
Andrew mentioned the Lionheart driver which I don't know a lot about except that it has multiple brightness levels which could be a cool thing for this, and I don't know how to set the current for it either.
Either way, are they ready to go as soon as I hook up the batt and LED connections, and set the current? Looks like I need to get a DMM.
The pros and cons of not only whether to go series or parallel are confusing, but also what circuit to use as apparently there are different choices no matter what configuration. Still a little foggy on all this, but all your answers are helping to put the picture together (I still need a lot more though... hehe). This is much appreciated.
EDIT: In response to the last two posts, these are the MJLED single large die 5mm's running 100 ma each.
