ViReN
Hi All,
After Looking at various Sections of the forum... I learnt that
1) We Do Battery Test for Various Batteries...
2) @ Various Current Drains
3) & of Various Sizes.....
To Determine True Quality / Power of Battries
But There is No Such thing (after searching through Runtime Plots)... for Flashlight...
I mean lets take Nuwai QIII & Compare that with HDS / LionHeart or other High End Lights... for Relative Output V/S Runtime
I always Seen A Flashlight Against Itself... and guys declare it as a Winner!... (runtime aginst time @ Various O/P Levels)
How can I compare Myself with Myself?... and then Declare that I am the Winner /ubbthreads/images/graemlins/grin.gif ... Ofcourse.. I will be the winner all the time /ubbthreads/images/graemlins/blush.gif
A Proper Comparison should be against taking some Bench Mark... like comparing Nuwai QIII Light (Price, Performance, Runtime) and then overall quality... compared with the Similar Shaped / Luxeoned Lights like HDS, Peak, Streamlights... and others...
Do we have such comparisons ?
Feel that there should be some sort of index (number) that will be a true representative over various factors...
Another Idea is... making a Excel File as a Database available... that will contain Relative Output & Time Data for Standard Sample time @ Standard Distance (light) measured. then... Individuals may compare acording to their likes/ dislikes for various lights... Adding the Battery Drain (Current) Data as the time passes by will be an added advantage...
I want to build up an Online Application that will Dynamically generate Graphs based on the various selectable parameters against time for various lights... .. problem is that.. i do not have anything to start with (especially the realistic Data)...
