Re: Modamag 3x3 3d with TYOH pics
Oh, I believe you bigtime sir. /ubbthreads/images/graemlins/buttrock.gif
I have a 3c 4x3 with 4 TWOJ binned leds, and it just ROCKS!
I also went the b2eze route with that one.
Unfortunately that kit may not work as I see it pictured if it is for a c cell light with so20's.
The bulb adaptor may not fit as mine didn't.
No biggie though, as you can always gut the mag bulb tower as I did,
for even more power to the leds by soldering them to the switch assembly.
Also, you may need to bevel the edges of that sink to get it to sit down all the way in with good thermal contact.
These are issues that b2eze is currently working on at this time with his nextgen copper sinks. /ubbthreads/images/graemlins/cool.gif
edit:
Welcome to cpf!!
another edit:
I let the nimh batteries calm down for a few hours before doing temp readings on that 3x3 TYOH setup.
Starting at 3.1 amps and running for 30 minutes ending at 2.6 amps with a room temp of 75F:
It reached a temp of 120F on the exterior of the bezel.
The sink inside reached a temp of 150F at the stars.
Clearly there is still room for improvement here, but it's looking good already. /ubbthreads/images/graemlins/smile.gif
Now the 4x3 3c TWOJ was left on for 45 minutes during one of my foot patrols through the building.
It started at 3.8 amps, and ended at 2.1 amps.
It was a few degrees cooler than the 3D due to the c cell nimh batteries wimping out.
This is the b2eze one also awaiting some improvements.
