Hello everyone, this is my first post here - I've had an idea for a project involving LEDs milling around in my head for a while, and a friend of mine said this would be a good place to come to ask some questions.
What I'm wondering at the moment is how much overdriving an LED will shorten its life? I'm looking into using fairly standard-seeming high intensity 5mm LEDs that are spec'd to run at 20 mA (30 mA "max"). Now, I know heat accumulation and how well heat can be sinked away will make a huge difference. At the moment, I'm not planning on doing anything special in that regard - in fact, currently I'm planning to have the LEDs in a tight cluster of three in a closed plastic housing.
Given those sort of circumstances, what could I expect to find in general in regard to the impact feeding these LEDs more current will have on their lifespans? Could I run them for a few hours straight at 25, 30, 40 mA, or what, without them burning out or going below, say, 2000 hours of life instead of the general claim of 100,000? In such an enclosed environment, could I even safely run them at the stated 20 mA typical current for a few hours?
I haven't been able to find any information online regarding this beyond that overdriving LEDs will shorten their life (or possibly burn them out entirely, if run continuously for an extended period of time instead of given periods to cool off) and that temperature plays a big role.
This is unfortunately a fairly specific question, and I can't provide more specific information on what precise LEDs I will be using. I've been looking at bright reds from ultraleds.co.uk or eled.com, for example. Is there any sort of general rule? Any sense or guidelines you guys could give me?
If I haven't annoyed you all too much with all the questions, one more: what about 3mm LEDs with similar specs?
Thanks in advance; I really hope you can help me out even a little on this matter.
