what do you look for when buying a flashlight?
cheapo
What does a flashlight need to have for you to consider buying it? /ubbthreads/images/graemlins/smirk.gif
MaxaBaker
South Jersey
Well, it's gotta be bright enough to hurt the eyes quite badly /ubbthreads/images/graemlins/wink.gif
It's gotta be rugged (I'd like it to be waterproof as well, but it's not a neccesity).
It's gotta look at least *a little* good.
And, I'm a throw lover, so except for rare cases (such as an L4), it's gotta have a lot of throw /ubbthreads/images/graemlins/cool.gif
beezaur
Reliability.
I am a reliability freak. I think Murphy has me on speed-dial or maybe lives next door. You know all that stuff that will never happen to you? Well, that is because most of it happens to me instead.
I usually like to buy high-end lights, since those typically have performance and features along with reliability. But reliability comes first when I look for a light to fill some role. Cheap and robust is preferrable to cheap and feature-packed.
Scott
Polar_Hops
I usually look for HAIII, Waterproof, common batteries, bright, pocketable. I hope the photon proton will be waterproof, in which case, i supose i can forget about HAIII, because i dont think they would hard anodize it =\
cheapo
Here is what I think:
*anodization
*regulation
*luxeon LED
*good beam quality
*THROW
*aluminum reflector
*water resistant at least
*tailcap switch
*under 5.5 inches
*uses CR123 batteries
*white tint
*the light has to look good
*warranty similar to Pelican's
-David
357
usa
1. Reliability
2. Beam Quality / good tint (if LED)
3. Fit Finish/Build quality
4. Runtime
5. Output:Size ratio
ACMarina
Brookston, IN
I look for something that fills one of the needs that I have at that particular point in time. That's why I've got so many different lights. .
TORCH_BOY
Australia, Vic
Quality, good feel in the hand, Beam quality, some regulation, good runtime, robustness and affordability.
leukos
Chicagoland
[ QUOTE ]
[/ QUOTE ]
Modularity and accessories. /ubbthreads/images/graemlins/cool.gif
BentHeadTX
A very strange dark place
Durability/Waterproof
Regulation
Brightness
Small size
AAA/AA batteries
LED
Variable output
Price
The big cannons I build myself, my nFlex WX1S Mag is my current favorite (not as an EDC though!)
gadgetnerd
Brisbane, Australia
Main considerations:
Build quality
Beam quality
Robustness
Small size
Run time
Price
Ability to get one too Australia without too much #^&$%ing around online.
rgp4544
My preferences, including ones not available yet:
High quality;
Long term reliability;
Ideally, dual output, with a very low low beam, low enough that if I use the low I will still be able to see in the dark when I turn it off, and a good throwing high beam, preferably incandescent high beam;
Idiot based switch that anyone can use (none of the switch based menu system type of junk as found on some lights);
Switch on the tailcap;
Must be easily operable with one hand;
Size, no longer than a Mini Mag, but not as small as most of the 1 x CR123A lights because if too small I find them difficult to operate;
Regulated output on both levels would be ideal;
Ideally it would be an item that I could maintain myself in the event of breakage...and I did once break an LED which didn't require the tremendous shock one would expect.
Ability to attach a lanyard, one long enough to hang it around my neck;
Ideally it would also be made of a non magnetic and non conductive material and will not cause interference in other electronic items.
Closest I've found to ideal is the SF A2, although I'm saving some spare cash to order an Aleph to attempt to duplicate the SF A2 output using 2 x AA's. I prefer CR123A's for use in the USA but have to fly all over the world and in most places you're more likely to see the Queen of England walking out of a public toilet than you are to find some CR123A's for less than $10 each.
Richard.
thesurefire
U.S.A.
What do i look for?
In order of highest prority first
Good warenty (who makes it)
Finish
If it has a good clip (or a chanable clip)
Vaule (or amount of light to $ ratio)
light amount
light quality (beam quality)
finish quality
2 stage (or addable 2 stage)
Who makes it
weight to light ratio
size to light ration
price (overall)
long term relablity
you may notice some odd things, like why relablity is on the bottom. well if they have a great warenty (top) i dont mind having to replace the thing a few times /ubbthreads/images/graemlins/grin.gif
FluffyGrunt
Regulation!!! /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/buttrock.gif /ubbthreads/images/graemlins/happy14.gif /ubbthreads/images/graemlins/sleepy.gif
Good build quality, fit and finish and such.
A switch I can trust.
Good runtime.
Useful throw or spill.
Regulation.
Usually Led.
Possibility of running with rechargeables.
Battery type.
Size, comfortable to use and carry.
Look, has to appeal to me at least a little.
Did I mention regulation?
VidPro
Lost In Space
Cheap Price
usable quality
high output (lux1 min)
Reduced parts (no regulation)
standard battery types, with possibility for rechargables
Smooth Beam, throw is OK as long as it will light a path ETC
size VS Runtime, meaning 1 hr is ok when it fits in shirt pocket, if its the size of a 2D mag, then it better run longer than a 2d mag does.
Price
MR Bulk
Hawaii
Smaller. Brighter. Better. Oh wait, that's SureFire's slogan.../ubbthreads/images/graemlins/grinser2.gif
Hey sithjedi333, you said:
[ QUOTE ]
Multiple light levels.
Fire~Fly II, SO17XA reflector, BB650
Fire~Fly II, SO17XA reflector, BB650, no logo
Fire~Fly, MM+ WO, 16ohm 2-stage
Aleph 1, 2x123, DB700
TigerLight
Laser Products 6Z, SureFire KL3
SureFire G2, modded to 3w LED
Maglite 2D
[/ QUOTE ]
But none a yore lights has that (multi-levels)...?
(sorry, just messin' with ya...)
