[ QUOTE ]
evan9162 said:
[ QUOTE ]
95% of the time the light is dimmed down to less than 1.5 watts so will I get increased life expectancy?
[/ QUOTE ]
Most definitely. 1.5W would be something like 250mA. I'd expect the Lux V to easily exceed 100K hours of life at that power level.
[ QUOTE ]
Can I expect 10,000 hours or more due to lower wattage and much less heat due to heat sinking?
[/ QUOTE ]
Yes easily on the lower wattage. As for the heatsinking, if you're talking about at nominal power (700mA), then maybe - possibly into the 1000s of hours.
[ QUOTE ]
Is the LuxV's downfall the heat or the phosporus?
[/ QUOTE ]
It's easily phosphor degridation due to heat. The green/blue Luxeon Vs have the expected lifetime of 50K hours like all other parts. I've hypothesized that the phosphor is cooked at lot more on a Luxeon V than in other devices.
[/ QUOTE ]
Of course you probably remember this evan9162, but for the benefit of others...
It is not at all, whatsoever, that they don't know yet or any silly thought like that.
Years ago, LumiLEDs released this part. Even though customers were abiding by all the design critera that LumiLEDs gave them, LumiLEDs denied it for a short period of time. After complaints from a multitude of respected folks in the industry showed LumiLEDs they were wrong and these Luxeon V devices actually had a problem.
The datasheet was quicky revised.
LumiLEDs engineers that visited me said they had a number of fixes already in testing. This was quite some time ago.
Had LumiLEDs actually fixed the devices, I'd be quite surprised if they didn't fix their datasheet. It would only take 42 days to determine if the changes helped for certain. By 84 days, you'd know if you'd extended the lifetime of the part to 1000 hours. So I don't buy the, "they can't tell yet line...", as this part is years old.
They know, and its been tested very specifically, so they are giving you hours of life very specifically, under very specific conditions.
If affected only a portion of the population, they might even give a statistical distribution for typical parts. They didn't.
Also keep in mind, many of us cpf'ers put very robust heatsinks on huge D cell Maglites, and used quite substantial heatsinks, hotlips was a common design. It would be interesting to put thermalcouples on one of these while in the flashlight.
Keep in mind that when overdriving these LEDs, the life does not decrease at a porportional linear curve, but follows a dramatic exponential curve. Overdriving brings on loss of light much faster.
Also your eyes are not linear, but logarithmic, and if you weren't doing side by side comparisions, it would be doubtful you'd notice.
One point I do recall, folks kept thinking Gransee had improved their ARC AAA design, as it was so much brighter than their old one they have. No changes, just their LED had degraded, and they didn't realize it. The ARC AA and AAA over drove it's LED by quite alot, so they degraded rather fast.
