I've been asked to hook up a couple of extra speakers onto an existing 70v PA system in a hall. Poweramp is a TOA 900 series, rated for 60w (doesn't say RMS or peak), with a current total of 10 speakers. I'll be tapping a speaker each on the far sides of the room for power and add another speaker to the room extensions for a total of 12 speakers--may be bumped to 14 if need be.
Now, the little transformer on the back of the ceiling-mount speaker has one wire for 70v common, and then 5 more for 10/5/2.5/1.25/.625 watts. No markings on the speaker magnet.
I was going to wire it up using the 70v common 5watt wires (12 speakers total 60w amp). Is my reasoning sound (pardon the pun)? Or should I use the 2.5watt wire in case 14 speakers end up being used? thanks.
