sometimes i WISH that could be done.
this here broke one, which is a red 1W one from when they first came out.
the dome is 5.5mm the plastic (ring) the black part is 8.0-8.2mm.
the metal plate under the thing is 6mm about the same as the dome itself. the WIRES run through the ring thing.
once the black ring is removed there is Little to HOLD the dome on, being glued around the ring, and on the base thing.
so , from that i would make these assumptions.
the wires are going to be in the way
the thing is going to fall apart easily or instantally
the DIFFERENCE between the dome size and the ring isnt doodley.
The metal base is almost as big as the ring.
its not worth it in any way.
the faux luxeons made in china and taiwan, dont have the same base stuff, so they stick up further with less in the way, but i really think they are not as good. but for sticking up further with less in the way, and not having BLACK around them.
what dummy trying to reach Max Lux/watt ratios blows .1% of it out into a Black hunk of plastic anyways, when they coulda put clear or reflective there.
No luxeons were harmed to provide this info, that werent already /ubbthreads/images/graemlins/smile.gif
