Nerd, amp hour capacity does not accumulate in a series hook up; (3) 3Volt 1.3 amphour batteries in series (ie. end to end) will give you 9 volts for 1.3 amphours of use. (2) 1.5 volt 2.9 ah batteries in a series will give you 3 volts for 2.9amphours..to compare them multiply amps X volts to get total watts available;
3 Lithiums= 9v X 1.3ah = 11.7 watts
2 AAs = 3v X 2.9ah = 8.7 watts
...the lithiums still win...
<edit> - or is it 'watthours'?..so a '5watt' LS would burn for about 2.34 hours, compared to 1.74 hours for the AA's..I think..real world figures will vary)
