Apr 22, 2005 #1 Sinjz Flashlight Enthusiast Joined Oct 4, 2003 Messages 1,120 Location six blocks from ground zero - WTC/NYC This is one of those 365 5mm UV LEDs. The spec sheet says 3.6 volts and 20mA. I'm guessing a X1 circuit is more than 20mA, but I'm not sure. Is this NSHU590B thing only suppose to be used with keychain lights? TIA.
Apr 23, 2005 #2 M markdi Flashlight Enthusiast Joined Jun 27, 2003 Messages 2,403 Location Portland Oregon I think that the converter board in the flashlight will not be damaged at all. the uv led could die young
Apr 23, 2005 #3 greenlight Flashlight Enthusiast Joined Aug 18, 2004 Messages 4,298 Location chill valley because..?
Apr 23, 2005 #4 M markdi Flashlight Enthusiast Joined Jun 27, 2003 Messages 2,403 Location Portland Oregon if the x1 overdrives the white led then it may overdrive the uv led. I do not know how much current the x1 supplys to it's stock led. I do not know how a Nichia NSHU590B handles being overdriven.(probably will handle it just fine - you will probably not use it as much as a white x1) I am pretty sure you will not hurt the converter electronics.
