Bradlee
I recently obtained a micromag/Mini-minimag [1 x AA cut-down mini-maglite, for those that don't know] (Thanks Reefphilic!) and am wondering what I need to know about the opperation and modification of this type of light.
I am thinking specifically of ruinning a NexGen 750 on a 14500 Li-Ion (as I have seen others do). I've noticed suggestions such as letting the battery sit for a few minutes so as not to overpower the circuit too much, but are there any other simple things I should know?
For instance:
-Will heat dissipation be a proglem if I am not holding the light?
-Should I be using a heat conducting compound to ensure heat is transfered to the body?
-At such a high current, is the internal resistance of a kroll switch negligable?
-How bright would it be compared to a benchmark light like the QIII?
Right now I am running the stock bulb on a cell taken from a CRV3, but I notice a funny (acidic?) smell from the battery compartment when I take off the tailcap (not having been used for very long). Is this typical? I don't notice any leakage from the battery but thought it might be gas (hydrogen?) which is naturally released by a Lithium battery. I am carrying the light arround my neck, so I don't want the light to blow up or anything!/ubbthreads/images/graemlins/str.gif
Thanks in advance,
-Brad
For instance:
Thanks in advance,
-Brad
