Weylan
I have a friend that makes glass jewelery. Beads in fact. They are clear with a ton of detial on the outside. She has them for ear rings. Most of the time they just look like glass bead ear rings, but if you feel them by hand you can feel the texture and detail. I suggested that she might use an LED inside to help people see the detail while they are on display.
This got me thinking of how small an LED we can get to put inside and back light the detail of the beads. Or how small a driver we can get to make the ear rings light up while wearing the beads as ear rings.
I could use all suggestions for micro LED drivers too. I bet lighing them up for a couple of hours would be fine off of some really small button sells would work. So how small can we go to make an LED driver and LED package. The LED driver does not have to go inside the bead, but the LED does. I was thinking we could hang the driver from the ear ring hook behind the ear, hidden, so we would be able to use some slightly larger batteries for longer run time.
Thoughts?
Thoughts?
