2wheeledslave
- Joined
- Apr 22, 2005
- Messages
- 9
Hey, I'm looking to make my own LED turn signal for my motorcycle, but need a little help. I'm not completely clueless when it comes to electric problems (I've learned a little through engineering classes), but I don't want to just dive in and expect things to work since most of my classes teach theory or ideal situations. We all know the real world doesn't work like that.
The nuts and bolts:
I want to use one Luxeon Lambertian ( http://www.theledlight.com/pdf/Luxeon/Emitters.pdf ) if possible. This is pretty much the only thing that I'm pretty set on using right now assuming you all think it would work ok. The design would be similar to the one in this link (I don't want to buy it due to the high price tag) http://www.greggscustoms.com/600rr_f4i.htm
Questions:
1)Do you think this LED would be bright enough?
2)Obviously, my bike is a 12V system, but I've read that the voltage will actually fluctuate, so what resistance would you suggest? I would run the resistance in parallel right?
3)I wouldn't think that I would, but do I need a small heat sink even though it's not on constantly?
4)Is there anything I'm not considering (besides legallity) that I should know about?
Sorry for the probably easy questions, but I don't want start throwing it all together only to be frustrated later on. Any and all advice answers are greatly appreciated because I'm not sure I'll delve into this without some knowledgeable help from you. Thanks!
The nuts and bolts:
Questions:
