Re: 6V MR11 running at 7.2 - work, and for how lon
well for lack of a better solution, if you are worried about the 7.2v on the 6v bulb, you need to increase the resistance in the current path to the bulb. In a conventional flashlight where the bulbs and powersource are essentially in the same housing, you would have to place a resistor in line. Whereas with a bike light you have a potential advantage. You can use thinner gauge wire running from the battery pack to the lamp to provide a small amount of drop in voltage to the bulb. NOW I AM NOT SAYING TO USE 30GA SINGLE STRAND HERE! You don't want to catch yourself on fire! You will need to do some calculation with regards to bulb current draw at a given voltage, length of wire from battery to bulb AND back. You can probably get away with having 0.6v drop in the lines, giving the bulb 6.6v probably not killing the bulb. However as stated above, fresh off the charger, the pack voltage may be near 9V initially. This will not correct for that, and you may instaflash. From a safety standpoint, I would HIGHLY recommend using a fuse at the battery, of reasonable rating, as these packs can dump 40-50A into a short!
