VidPro
ok as you know i been trying to make a 2D to 3D MAG mod
it uses 3 Nicad D cells, that i had laying around
and 3 LuxIIIs and modamags tri-star type synk
and a bunch of stuff from the garage /ubbthreads/images/graemlins/smile.gif
Some of the pictures are really out of focus, but its good for having Mod in one hand little no-zoom camera in the other.
CAPTIONS are UNDER the pics.
i am gonna try and fit all this stuff in the tailcap, and then some
this is the postive contact button , and the wires that will go to the luxes. its a Screw, with raw copper wires soldered to the tip. a neoprene washer and shrink tubing , keep it from makkng contact with the synk.
This is the screw button thing , inserted into the heat synk
this is realizing that the bare wires must be covered, so more heat shrink
that is how it should fit when i am ready to install it in, i still have to mount the stars
the stars ground down, and made very rough so the epoxy will hold forever (a 100% unnessisary step usually)
Squeezing out the Last of tubes of jbweld, i wont need much, and i used to much.
Jb under the synk to lock it into the mag head permanentally.
The 2 surfaces where "ground together" i spun the synk with the drill, and that ground the surfaces to match eachother, then (way to much) jb weld was put on those ground surfaces
Jb under the stars, of course to much again, but it'll sQuuuuish out during clamping.
see way to much, thats it OOOZing out , ready to jump on the threads and make my life heck. i cleaned off most of it, and checked the threads, before clamping
ready to clamp, i stuck actual optics in, because , well what else was going to fit over 3 heads right.
then i put rubber washers on the top face, and rubber behind the head, and clamped it down in the vice, using just the right pressure.
if i did it correct, there would be Power conduction, from the head, to the synk
