LED-FX
Comment from Don Klipstein, http://members.misty.com/don/, on sci.engr.lighting:
>>>Take a look at their latest version of DS46, the datasheet for "3 watt"
Luxeon Star:
Characterized light output is achieved with 1400 mA of current, and the
typical voltage drop at that current is 2.95 volts. This indicates a
typical power consumption of 4.13 watts to achieve this. 190/4.13 works
out to about 46 lumens/watt.
The "1 watt" "lambertian radiation pattern" red-orange part achieved 55
lumens with a typical voltage drop of 2.95 volts at its characterization
current of 350 mA (1.03 watts), or typically 53 lumens/watt, according to
a version of the DS23 datasheet that I got last year.
Furthermore: According to these datasheets, this is with the junction
temperature being at 25 C. Check out the thermal resistance figures in
these datasheets, and you will find that achieving that requires a
heatsink temperature of about 4 degrees C for the 1-watt part and about
-16 C for the "3-watt" part.
Light output for the red-orange "3-watt" part with 1400 mA and heatsink
temp. 25 C has typical voltage drop of about 2.87 C, power input 4 watts,
junction temp. 65 C give or take less than a degree for "center value of
typical" (my words), and light output about 64% of that achieved at same
current and 25 C junction temp. (Look for light output as a function
of junction temp. on page 9 of the version of DS46 mentioning red,
red-orange and amber parts.) This works out to about 30.5 lumens/watt.
The "1-watt" version fares better: With heatsink temp. 25 C I figure
junction temp. close enough to 45 C and typical voltage drop of 2.91 volts
and this at 350 mA is 1.02 watts. Typical light output in this case is
about 79% of that with junction temp. of 25 C, for about 43.5 lumens or
about 43 lumens/watt. This is according to a version of DS23 that I
downloaded last year.
Also please consider that a heatsink temperature of 25 C is awfully
optimistic. It surely appears to me that a heatsink has to be of close to
"overkill" size to achieve 35 C temperature of the heatsinking surface of
the part in question, and for a Lumileds red-orange LED that means about
8-10% less light than is achieved with 25 C temperature of the heatsinking
surface of the LED.
Red LEDs are worse than reddish-orange ones and amber ones are not as
bad as reddish-orange ones in terms of output and efficiency/efficacy
varying inversely with temperature. Better still are green, bluish green
and blue ones and white ones, although temperature sensitivity of white
and green ones is significant. Blue ones have performance varying least
with temperature. <<<
Pass me the LN2 tank just like Lumileds et al, use in the lab ;-)
Adam
Luxeon Star:
surface of the LED.
Adam
